JD 14T missing knots
CB in central N
06-23-2005 06:58:04
Greetings.
I know this has been somewhat covered in the previous posts (and yes, I probably need to get a manual). But we are having a nice streak of weather here in CNY and I've gut a bunch of hay down so I am hoping for some quick advice.
I have a JD 14T which I run with a hay accumulator. Out of every 30 - 40 bales or so a couple will fail to tie (it is usually only the left-hand knotter , the one closest to the outer edge of the baler). The other weird thing is that when the knotter fails to tie, it's almost always two bales in a row. Then things go back to normal. BTW, I use 7200 sisal twine.
I've read that the needles may have to be adjusted with respect to the twine disks. I have two questions. Are the twine disks the ones that actually cut the twine? How exactly do you adjust those needles with respect to them?
Thanks for reading.
Ed Sutton
05-25-2006 09:47:34
 Re: JD 14T missing knots in reply to CB in central NY, 06-23-2005 06:58:04
Although this is a year late, for you, now, as I just found this forum recently, I'll still offer a suggestion. One suggestion would be to check for 'play' in the left intermittent knotter gear. That is the disc-like apparatus, with intermittent 'teeth' inside, that turns the whole knotter assembly. It is aligned with a square key. Any movement shows wear in the disc, the key, or the shaft. A little wear allows the left disc to 'lag' behind the right one slightly. The result is that the knotter is out of 'time', slightly, and the billhook closes on only one strand of twine, in place of two as the knotter 'ties'. Couple this with worn restrictor plates on the side of the bale chamber, and the 'expansion' of the hay combine to pull the knot loose as the plunger retracts. We solved our 'problem' with an oversize key, of only a few thousandths, which my nephew was able to acquire from where he worked.
The baler is still 'worn out', has baled multiple thousand bales over almost 50 years, sat unused and rusting away in a machine shed for at least 15 years, has rust holes in the bottom of the bale chamber you could "throw a cat through" and when fixed with the oversize key, went right on baling with almost no misses like it did twenty years ago after I ran about 50 bales (actually four bales about tweleve times) of old hay through in to loosen up the knotters and the rest of the parts to loosen everything up. I did break down over the summer and bought a 'new' baler on eBay, a 24T for $400.
Ed
Warren in Wisc.
06-23-2005 12:53:09
CB,
All good advice so far. I know what you mean about having hay down now and need advice. My 14T was doing the same thing as yours, but sometimes it was 3-4 in a row. On mine, the knot was hanging up on the bill hook. As more hay pushed into the chamber, the pressure broke the twine still in the bill hook. The next bale wouldn' tie because of the previous bale's knot still stuck in the bill hook. After wrestling with it for some time, I happened to swap the postition of the twine in the twine box. I don't know if I was feeding the left from the left or from the right, but I do know that it solved the problem. I imagine that it had something to do with the twine tensioner as the twine comes out of the rolls - I imagine that one was tighter than the other although I couldn't feel any difference. It doesn't make sense to me that the twine tension could affect the knot releasing from the bill hook after the tie, but it quit missing! At the time it didn't matter and I ain't gonna mess with it now!
Good luck
TimS
06-23-2005 18:02:55
 Re: JD 14T missing knots in reply to Warren in Wisc., 06-23-2005 12:53:09
Warren that is the same thing our 14t was doing with the twine coming out of the wrong side of the twine box, it is caused by the knot being formed IN the billhook instead of AROUND the billhook. If the twine isn"t in the right spot ( due to lack of twine tension in our case ) the billhook can grab the twine and form the knot in the bill hook instead of around the billhook.
Once it does that the wiper can"t wipe the knot off so it is stuck. Normally the billhook is only holding the two pieces of twine that are coming out of the knot for the knife part of the wiper arm to cut when it passes...
TimS
06-23-2005 12:26:35
As somebody else mentioned, what does the knot look like when it isn't tied correctly?
Is there a knot in either end of the twine that goes around the bale?
If the twine is twisted on both ends like a knot was formed but slipped apart, you can increase the billhook tension by tightening the nut that has a spring under it on the end of the billhook. That will cause the bill hook to hold onto the ends of the twine that come out of the knot more firmly to tighten the knot so it won't fall apart. If you tighten the bill hook to much, the wiper arm won't be able to wipe the knot off the billhook, so just adjust it a small amount at a time.
The discs hold the twine while the bale is being formed. The twine is cut by a knife on the wiper arm which is what 'wipes' the knot off the billhook after the knot is tied.
You adjust the needles to get a tiny bit of clearance between the needle and the disc on the bottom and the knotter frame on the right by loosening the bolts that hold the needle to the arm that moves the needles up thru the bale chamber and then adjusting the needles side to side or up and down to get the clearance you want. A tiny gap or even barely touching the knotter frame is ok, the needle needs to just clear the disc.
The tucker fingers grab the twine as the needle brings it up and put it in position for the disc to grab it as well, check that the tucker fingers are activating, they are the half circle discs just on top of the bale chamber underneath the knotters.
Check the chains for excessive slack or wear, our 14T worked much better with a new set of chains. They are cheap and easy to change as well.
Make sure you are feeding the left knotter from the left twine box and the right from the right to keep the twine tension correct. I had that crossed last season and had a devil of a time figuring out the problem with the right knotter, it's twine path was so short the knotter was very inconsistent in tieing due to the lack of twine tension.
My 14T manual is with the baler down at the in-laws, but let me know some more info and I can try to help a bit.
Last thing, what is your bale tension set at, if you don't have enough tension it can cause problems tieing consistently. To much tenstion can cause knots to come loose and twine to break as well, you have to find a point between those extremes.
CB in central NY
06-23-2005 19:01:44
 Re: JD 14T missing knots in reply to TimS, 06-23-2005 12:26:35
It"s harder to explain than to see, but the knot looks like one of the cut ends didn"t make it through the loop. Then it can easily slip apart.
There is no knot on either end of the twine, but the ends do look like they tied and just slipped apart.
Jerry D in NC
06-24-2005 04:59:19
 Re: JD 14T missing knots in reply to CB in central NY, 06-23-2005 19:01:44
If the knot is tied in the end that is on the top of the bale and the end that is on the end of the bale is slipping through then you have a tucker finger problem. You need to find a manual for that adjustment but it is one of the easiest things to adjust and one of the most critical
Farmer in the Dells (WI)
06-23-2005 11:45:08
I'm not sure that twine tension would cause that problem so infrequently but would not hurt to check it. Make sure all the guides for your twine are not grooved, or missing. If they are grooved give them a turn so the twine slides freely through them again. Those guides are available at any Deere dealer if not at your local Farm and Barn store. I use 9000 sisal in mine without too many problems. Sure I lose one now and again but expect that from a machine this age. The manual will pay for itself for the lube chart alone. Have you lubed the point in the middle of the intake auger? That is what the little hole is and needs to be rotated to line up with the grease point. Just bought a throw wagon and next season will be throwiing them into the wagon for the first time. One field has been down for enough time that I am on my way out to hook one up right now. Good luck. Been using my 14t(s) for ten years with very good success.
Bill in Washington
06-23-2005 10:48:31
Give me some more info on what the twine looks like on the broken bales i.e. half knot on an end, two twines in place of one or only one twine per bale etc. My guess is that this problem is not needle related but in the wiper arm or tucker fingers. the sand paper is a good idea but that should of corrected the problem by now. you may also want to check your twine tension on the problem side.
CB in central NY
06-23-2005 19:06:56
 Re: JD 14T missing knots in reply to Bill in Washington, 06-23-2005 10:48:31
There would sometimes be a half knot on the end, but then sometimes the ends would look like they tied but simply slipped apart. And the culprit is mostly just the one side, closest to the outer edge of the baler. Back when I first got it, that side had an original 14T billhook, which missed just about every other bale. So I wend to the local JD dealer and bought a "multi-twine" billhook. It made a huge difference but didn't take care of the problem entirely.
Hay Farmer in IN
06-23-2005 10:48:24
The manual for our 24T shows a list of pictures relative to the bad tie. Is the knot on the bail side or the needle side?
CB in central NY
06-23-2005 19:09:39
 Re: JD 14T missing knots in reply to Hay Farmer in IN, 06-23-2005 10:48:24
I am not quite sure what you mean "bale side or needle side". The knot is on top of the bale just as it clears the knotter assembly.
Hay Farmer in IN
06-23-2005 10:45:24
Colorado Curt
06-23-2005 07:07:08
The disks grab and hold the twine when the needles come up. The needles may need to be adjusted so they deliver the twine at the proper time and location. You will need a manual to get this done. We had a problem with a 14T where we could not get this adjusment consistent. The root of the problem was a wobbled out hole in the arm that actuates the needles. The manual does not cover that!
roper6365
06-23-2005 07:39:24
 Re: JD 14T missing knots in reply to Colorado Curt, 06-23-2005 07:07:08
I have a NH but one common problem is the Bill hook getting rusty on the bottom over the winter. It won't let the twine slide off in time to tie. It's an easy check, take a little superfine sand paper and clean the bottom. Hope it's that easy for ya!
Steve (Magnolia, TX)
06-23-2005 08:23:50
 Re: JD 14T missing knots in reply to roper6365, 06-23-2005 07:39:24
Something that I found useful on the MF124 that we're using this year, is a little talcum powder, as a lubricant, on the knotter and bill hook. It's just enough to keep things going until the friction of the twine 'polishes' the hooks, etc....
HTH
Steve
mike brown (in cny)
06-23-2005 11:52:20
 Re: JD 14T missing knots in reply to Steve (Magnolia, TX), 06-23-2005 08:23:50
There are hay restrictors that look like fish scale plates in the chamber that keep the hay from bulging back into the chamber. If they are worn out the hay can push back into the chamber when the needles come up pushing the twine up out of reach of the bill hooks so it only catches the twine on top of the bales. It's even worse in straw.
