Info for hay equipment buyers
KEH
06-22-2005 17:07:40
Ag Supply sells Morra disc mowers. I found out that these are the same mowers Long sells, except that the frame at the 3ph is different. As I have said before on here, one of my pet peeves about disc mowers is poor(IMO) transport lock design. These mowers have a mechanical trip lock that is disengaged by pulling a rope. Others with this system that I know about are Lely-Vermeer, New Holland, and Kuhn. Some first line makes like Agco(Hesston, New Idea, MF), Krone, and Class have a cut off valve in the hyd. line at the cylinder. Unless I am missing something this system depends on the O rings in the cylinder being in good shape, which isn't going to happen for long. Vicon(which I have) has a mechanical link from the end of the cylinder to the end of the rod, but the cutter bar leans over as the cylinder leaks down.
Comments?
KEH
