NH 66 baler knife
Sam C VT
06-21-2005 10:49:40
The fixed plate that the plunger knife cuts against on my NH 66 baler is very worn and rounded. Do I replace it or weld it and grind it square? Any tricks involved in getting it out to work on?
Thanks in advance - Sam C VT
Michael In PA
06-22-2005 06:32:16
 Re: NH 66 baler knife in reply to Sam C VT, 06-21-2005 10:49:40
Mine is pretty easy to take out, but keep an eye out for shims under the bolts. I sharpen mine on the bench grinder. I don't think it has to be a perfect edge, but having it sharp makes it easier on the baler and mkes for nicer bales.
Bkeepr
06-22-2005 04:05:36
I've never done it yet, but the manual says it comes off with just a few bolts. Book says sharpening should be done "frequently" to keep the baler working at top effeciency, and they even recommend keeping an extra one on hand. The book also says to sharpen, keeping as close to the original bevel as possible.
Not sure that helps, but nobody else answered so I figured I'd throw in what little I know. I plan on removing mine over the coming couple of weeks and sharpen, before I start mowing the second cutting.
Tom A
