Spare baler knoves?
Bkeepr
06-21-2005 03:52:54
How many of you keep spare knives for the plunger on your square baler?
Mine have gotten dull, and I don't take time to sharpen once the baling season hits, but I think getting a spare might make me more inclined to keep it sharp. I can hear the plunger strain when I gobble some heavy windrows, and some of the bales aren't cut clean apart anymore.
Anybody have suggestions on a source for a NH 66 plunger knife?
Tom A
BobMo
06-21-2005 19:47:29
 Re: Spare baler knoves? in reply to Bkeepr, 06-21-2005 03:52:54
Make sure when you check the gap between the blade you have the slack taken out of the bearings. Force them as close together (the knives) as possible before making your measurement.
Chick
06-21-2005 18:07:30
If your bearing and rails are tight, you can adjust the knife gap with shims behind the knives.
Hayman
06-21-2005 16:30:22
 Re: Spare baler knives? in reply to Bkeepr, 06-21-2005 03:52:54
Well the knives should go 10,000 bales no problem even 20,000 in the right conditions and work fine still. Make sure your knive gap is correct. It don't matter if your knives are sharp if your knive gap is too big. The gap should be around .010" to .030" between the 2 knives. Check your bearings and plunger rails for wear.
Typically I sharpen the knives and adjust the knive gap in the off season and then its trouble free for the summer.
thanks
06-22-2005 05:44:13
 Re: Spare baler knives? in reply to Hayman, 06-21-2005 16:30:22
Bought this thing very used from the original owner's son. They made a lot of bales in its first lifetime, and it doesn't look like the knives had ever been out or been sharpened.
You're right, the gap is way too big and I think I'll need to get new wooden guides too, besides just adjusting.
Bkeepr
Leroy
06-21-2005 06:36:04
It should last several years between sharpenings, at least they did on our 66 and later on our IHC 46 and that was with 10-15,000 bale a year
knives, not knoves!!!
06-21-2005 04:34:14
sorry, can't type this morning
Bkeepr
JMS/MN
06-21-2005 08:43:39
 Re: Spare baler knoves? in reply to knives, not knoves!!!, 06-21-2005 04:34:14
I met this King once, who said he always liked to keep a few spare knaves around the palace.
