NH 315 Hayliner Baler
rwood
06-20-2005 18:49:02
Broke the u-joint yoke on the pto shaft that connects to
the flywheel. Shear bolt failed to shear. Baler took in a large wad. Field full of hay. Big hassle. I'm trying to remember why I thought making my own hay would be kind of fun. Maybe I'll remember tomorrow after the thing is fixed, I hope.
chief 83
06-21-2005 20:37:00
 Re: NH 315 Hayliner Baler in reply to rwood, 06-20-2005 18:49:02
I also have a 315. I used to go through about a box of shear bolts a season. Last year I only used one. A little more HP tractor seems to have made the difference. Thankfully the shear bolt(s) are the only thing I've broken with the exception of a pully that just wore through. Good to go this season I hope--if it will ever quit raining..
BobMo
06-20-2005 20:26:17
I have a 315 and it will bale about anything. If your shear bolt didn't shear or the clutch didn't slip something is set wrong. Review your manual and recheck your settings. Good luck....
Roper6365
06-21-2005 05:23:56
 Re: NH 315 Hayliner Baler in reply to BobMo, 06-20-2005 20:26:17
Good advice, I'v got a 320 but not much different, I'm wondering of somone put new clutch plates in there and put to much torque on the bolts, That sheer bolt should have snapped.
