NH 68 Baler help needed
dej(JED)
06-20-2005 05:00:01
I got a 68 baler and didn't check it out all that well. When you turn the flywheel it won't roll. I diconnected the transmission from the plunger and the tranny and other mechanisms are fine, so the problem is in the plunger section. Are there any safety catches that could make it stick or might anyone know what is preventing it from sliding?
Thanks for any help.
Rexalot
06-20-2005 07:31:54
 Re: NH 68 Baler help needed in reply to dej(JED), 06-20-2005 05:00:01
Is this a standard 68 or Super 68? The data tag will have a "S" before the number designating the super series.
The reason I ask, the regular 68 baler plunger slides on "bearings" made of white oak bolted to the plunger, the other actually has a rollers. I"d find it hard to think that riding on wood it"d be froze unless there is no wood. Could be that you have rusted rollers? There are adjustments that can be made if for some reason the plunger is pushed to far to the right (as viewed looking fwd from the rear of the baler) should that be why the plunger is to tight.
What position is the plunger stuck in? Is it fully extended (in the bale chamber) or back clear of the feeder tines? How did you seperate the plunger from the gear box (at the "elbow" or where the fwd link connects to the gearbox)
I"ll guess that your only turning the fly wheel by hand at this point. If the plunger moves a short distance iin either direction of turning the fly wheel, it might be that the plunger stop that protects the needles from damage may be in the way.. baler out of time. Not sure how much experience with balers you have, but if you don"t know, the plunger stop is on the left side of the baler. It"s connected to the needles by a link. With the needles in the "home" position it should be clear of the bale chamber. ("Home" position of the needles is all the way back towards the rear of the baler.) Might check the "time" of things. Anybody got a link to KellyC"s website they could post?
Sorry I had more questions than help..
Chick
06-21-2005 18:10:54
 Re: NH 68 Baler help needed in reply to Rexalot, 06-20-2005 07:31:54
Make sure your needle arm is pulled all the way back. There is a safety dog that comes up, when the needles are not all the way back. These dogs stop the plunger from compressing the hay when the needles are in the chmaber, and breaking them.
dej(JED)
06-20-2005 07:48:41
Rexalot-Thanks. The baler needles are back and it appears that the baler may have just tied and the plunger was on it's return towards the tranny. I seperated the
the plunger by removing the 2 bolts that hold the plunger push pull arm to the excentric swivel. Also the baler seems to have 2 adjustors on the lower rail chamber below the counter, but when you look inside there appears to be wood shims?
Kelly C
06-21-2005 04:52:08
 Re: NH 68 Baler help needed in reply to dej(JED), 06-20-2005 07:48:41
third party image
Here is a photo of the plunger on a 68. Check out my web site for more 68 info. Find the link for NH68 in the left pane.
Our Farmer
06-20-2005 16:55:22
The wood shims are actually the bearings the plunger rides on. The screws are adjusters to adjust the relationship of the top of the plunger to the bale chamber. The plunger should ride 1/16th of an inch from the top surface of the chamber. You also adjust the plunger knife to the anvil.
