to turn or not to turn
daddyj
06-18-2005 17:22:12
If I drop the bales in the field is it better to let them dry as they fall or should I walk and turn them 1/4 turn the next day or so? I can't beleive all of the questions you guys have helped me with!!! What a great place.
paul
06-19-2005 14:31:04
 Re: to turn or not to turn in reply to daddyj, 06-18-2005 17:22:12
Small squares should get under cover as soon as you can. they should be dry as they come out of the baler.
Some balers have a turning chute on the back, sets the bales on their sides. This does help a tiny bit under some conditions.
However if you are using time to walk the field & turn the bales, stop wasting time & use that time to load & remove the bales from the field. You want them put away dry, & you want the grass to be growing for next cutting, not hay bales killing it & tracks through the field later smashing down regrowth....
That is how it is here in MN anyhow. :)
--->Paul
no. 2
06-19-2005 13:24:54
I have left hay in the field only one time. I sold the bales in the field, the buyer was to pick them up and haul them. That deal worried me for three days until they were all gone. I fixed a bale chute on the back of the baler to turn the bale a quarter of a turn so that the cut edge was up. I assumed that the flat side down would draw moisture and if nothing else damage the strings.
BobMo
06-18-2005 19:48:22
Apparently you haven't asked enough questions. Keep asking and your gonna get this thing yet..Good luck
sammy the RED
06-18-2005 19:32:39
If'in your baleing them, they should be dry already !
wolfman
06-18-2005 17:33:18
If you drop them in western Pa, you better pick em all up before bed time. It'll rain on them by morning! Then you will have to play with them.
msb
06-18-2005 18:28:17
 Re: to turn or not to turn in reply to wolfman, 06-18-2005 17:33:18
That goes for Indiana too.We used to stand the bales on end if we couldn't get them all picked up if it looked like rain.That way they only got wet on the ends for the most part.I wonder----- -how many bales I have stood on end???? HMMMMM.
msb
06-18-2005 18:27:28
