loading a wagon with sq. bales
daddyj
06-17-2005 19:12:32
On a 12.5 ft. wagon is 7 layers to many to stack? Do you stack each layer starting with the bottom and cover the wagon solid and then move to the 2nd and so on and so on? I find myself thinking of this all day at the office and am too embarrased to ask the farmers that come in. Do I need a back board? I have heard mention of "6 high and a tie". Please explain.
Leroy
06-19-2005 06:51:08
 Re: loading a wagon with sq. bales in reply to daddyj, 06-17-2005 19:12:32
Starting at the bottom and covering the whole battom then going to the next layer is only for loading out on a mow onto wagon, you do not want to walk on those bales as your loading as not only would it tire you out too fast (AND GIVE YOU HEAT STROKE) it would cause you to step in a hole between bales and break a leg if it didn't cause you to fall off the wagon, be safe not sorry and you do need something on back to keep load from falling off back with a little bounce of wagon, height of loading depends on how tall you are and your reach and barn door or electric wire opening height.
tim[in]
06-18-2005 07:38:26
i usually put the first 4 bales [2 on 2 on the corner of the wagon for weight to hold the front end down and keep the other bales from bouncing off. makes for a much smoother and safer ride. if you get some heavy bales you can replace the 4 counter weight bales or put the bales the come out of the bler chute from the previous baler. you know the half hay , half straw ones ,etc.i usually put the cut side [ the edge that is slice by the knife in the baling chamber] on the back edge of the baler .the "cut"side is usually a tiny bit taller. so the back tier of bales will lean towards the front and then the rest of the tiers will be placed with the cut edge towad the front so the load supports and leans against itself. if you get really good you wont even need the "ladder" on the back of the wagon. also we pull the bottom bales out a hair so the load is wider at the bottom and smaller at the top. kind of pyramid shaped.in the barn , we stack on edge [cut side down] so there is better air flow and drying. kind of wicks the moisture upwards and out of the hay pile. hope this helps.
BobMo
06-18-2005 07:08:27
Stack it so it don't fall off everytime you make a turn or hit a swag. No 2 people stack the same. If its tight and you put in a tie every couple tiers it'll be fine..... ....
Galen
06-18-2005 06:05:13
I agree - alternate the way you stack the layers, get a back board and DON'T WORRY ABOUT WHAT OTHERS THINK. My brother used to tell me "You can't do it that way", or "It won't work like that". Seems that every time I'd do something, I'd have a audience. After a while they just disappeared - they couldn't stand being proved wrong. Don't worry about being able to "fit in" with them - just run your operation as you se fit. You'll figure out what works for you in no time.
billOH
06-18-2005 05:56:48
We stack like this:
BACK OF THE WAGON
FRONT OF THE WAGON
= represents two horizontal bales
! represents on verticle bale
The diagram above shows how a full bottom layer looks; as you add layers, the "key" (ie the verticle bale) changes positions so that no two keys line up.
Jerry D in NC
06-18-2005 05:27:19
All of the below methods will work fine. One thing to make sure of though is to have tight bales. Loose sloppy bales can not be packed tight no matter how hard you try.
I go 6 high because that is what I can reach being vertically challenged and very gravitationally successful ( Short and Fat ) LOL
TimS
06-18-2005 05:16:11
A bit of advise, don't worry about what anyone else thinks about how you mow, rake, bale, stack whatever. If anyone makes a comment, say "I like doing it that way, it works for me." And smile.
Anyhow, hay wagons are easier to start a stack with a back rack on it to stack against. They don't have to be much, two pieces of angle iron bolted on at the bottom and some flat pieces of steel to brace it with to hold it up, a piece of wood ( 2x6 ) every foot or so to hold the bales in place and you are done.
I usually start out stacking the bottom lengthwise, next row crosswise, but some folks in here have good ideas in well. Whatever works for you is how you should do it, the important thing is the hay gets out of the field before it gets ruined.
I like to put the hay wagon behind the baler and make one pass and be done, father in law wants to put the bales on the ground and go back with some hired help to pick em up, we are still debating back and forth but since I will stack on the wagon and he can drive the tractor I think we will do it in one pass.
We can go up to 6 rows high and it will fit in the barn just barely, so that is mostly what limits us. I stack the back of the wagon up that high then fill towards the front.
TimS
06-18-2005 05:08:55
daddyj
06-18-2005 03:55:33
1 more?. Do I need to hitch the wagon(rack) to the baler or can I pull it with a tractor after baling. Seems better to do it all in one trip. The only problem I see is maybe the jumping of the baler will break the load and then when it falls off the guys "at the filling station" will really laugh. My field is right next to the road. You would not beleive the "traffic" when I am trying to work in that particular field. Anyone else have this problem?
Leland
06-18-2005 14:40:40
 Re: loading a wagon with sq. bales in reply to daddyj, 06-18-2005 03:55:33
9 times out of 10 we would drop the bales on the ground so the baler could run faster and not have to stop then we had 8-15 guy's infield 3-5 on each side of wagon and at least 2 on wagon stacking and another 10 or so in the barn and we usually had 3-4000 bales in barn and finished by 8 pm and then unloaded the last wagons a few days later by our selves.
daddyj
06-18-2005 16:41:45
 Re: loading a wagon with sq. bales in reply to Leland, 06-18-2005 14:40:40
Leland, You must have had a big field. Mine is not quite that big. I only have the one wagon. You must have had 2 or 3 wagons to get that much done.
paul
06-19-2005 14:45:07
 Re: loading a wagon with sq. bales in reply to daddyj, 06-18-2005 16:41:45
I'm a one-man operation, sometimes my wife drives the tractor to bale (now I got both a bale basket & round baler).
It is much better to load on the wagon as you bale pull wagon behind baler _if_ you have a stout enough tractor & you have 2 people, one to drive, one to stack.
Bending over & picking up from the ground & up onto a wagon with the bales is a big job. I do 2000 - 6000 bales a year.
--->Paul
Leland
06-18-2005 20:06:08
usually when this was done we had 75 or more acres laying on the ground.
Dave H (MI)
06-18-2005 06:54:04
I've done it both ways. Personally, I prefer a second pass picking bales from the ground. No baler noise/shake and you can work at your own pace. Plus, I never seem to have a shortage of locals who run out and throw bales on the rack. I end up just standing up there stacking them. Don't let neighbors ride the wagon until it is full and we are heading back. Free hayride and they never stop talking about it. Remember if you load from baler to make sure your hay is as dry as you want it in the barn. Bales will actually dry more laying in the sun for a few hours and I like that aspect too. Stop worrying about what those guys think and tell them they need to show you how it is done. Make some friends and get some free labor.
paul
06-18-2005 00:11:11
The key is to change the direction of bales every 2nd or 3rd level. Do not stack them like cement blocks one on top of the other, but do the stagger thing. Makes a solid load.
On my 8x - um, I don't know how long my raks are???? Anyhow, I stack 3 wide across the bottom. Yes you get a good 1/3 of a bale overhang on each side. I do this 3 high.
Then the 4th & 5th row I put one bale lengthwise down the middle, and put a bale on each side like the bottom rows, across the rack.
The 6th row is 2 bales wide, across the rack.
This ends up with a load of bales shaped like a loaf of bread, gets narrower at the top. It is very stable. The couple of bales running length-wise really stablize the load fore & aft.
While many people will run some rows across, and other rows lengthwise to make a sturdy load, I find thos emiserable to unload by myself. I have a drive-in hay mow, and it is really rough to pull those bales off the rack while standing on the floor.
My plan allows one to pull the bales down & off the rack with a bale hook, no climbing up to get bales down, then come down to stack, etc.
I use a rear rack to start the bales. Sure makes it a _lot_ easier. You can manage without, but an empty bale rack bounces a lot, very hard to start your rows & keep bales from falling off.
I stack all 6 high on the back row or 2, and work my way forward. I would not want to do one whole layer, then the 2nd layer, etc. Would not work well that way.
--->Paul
Leland
06-17-2005 21:50:12
the way I always stacked on any wagon was to stair step it , and as long as it rides and the tires are not flat go for it.
Kelly C
06-17-2005 21:38:08
Here is what I do.
8 foot wide by 16 foot long rack.
Start bottom row lenth ways 5 bales. I.E. the butt of the bale is facing you.
Then 2nd row 2 accross then center bale lenth ways, then 2 more accross.
Repeat as needed. Lenth ways then accross.
I go full rows 4 high. The for the 5th row. I center 2 bales accross the top, but set in a 1/2 bale. That way the top row wont fall off the back.
I then put one bale accross the center for the 6th row.
Gives a rack of 124 bales.
I drag these full racks 30 mi at 30 mph and have not lost one yet.
Nebraska Cowman
06-17-2005 19:37:11
We seldom stacked higher than 6 at home because we unloaded inside the barn. If you start with the first layer bales crosswise and let them hang over the edge up to 6 inches or so maybe the second layer the same, then the next two layers lenghtwise (5 bales across on an 8 foot wide rack) then the 5th & 6th layers crosswise again and pulling them in you can get over 200 bales on an 18 foot rack with no backboard. the secret is to start wide, drive slow, and keep your bales tight together. Once loaded you have a solid mass that will not fall off or upset under most conditions. Driving too fast at the start and the bales bounce around and you do not get a good tight load.
edchainsaw
06-17-2005 21:13:22
 Re: loading a wagon with sq. bales in reply to Nebraska Cowman, 06-17-2005 19:37:11
been a while since I have done much (alergys ran me to big rounds)
one time I rember as a kid getting 9 high (it was on a 20ft donahue planter trailer and one hint... start at the back and work to the front so the guy pullin the wagon can see when your ready to move.
