Desperate for bearing
peeforty
06-17-2005 17:22:25
If someone can find me a bearing and housing for an Indusco disc, model 201, I'll make it worth their while for pulling it off an "out to pasture" rig. I need the bearing, and housing that goes on the axle (4 bolt unit that covers the 1 3/4" nut)I've searched the internet with no results.
Dieselrider
06-18-2005 03:33:22
 Re: Desperate for bearing in reply to peeforty, 06-17-2005 17:22:25
If you cannot find a replacement bearing to fit the axle, take the axle to a macine shop and have them modify the axle to take a bearing that is available. "If you can't lead the horse to water - bring the water to the horse" This ain't "rocket surgery".Hehe
msb
06-17-2005 20:14:21
Have you tried Bearings Incorporated or Bearings Headquarters?
Jason(ma)
06-17-2005 17:47:49
Is this a bearing that is no longer available? Have you tried to see if someone like Agrisupply has one that will fit the disc's shaft? I think I saw some 1 3/4 round shaft bearings listed, or do you mean it takes a 1 3/4 socket?
Dick Rogers
06-17-2005 19:32:50
 Re: Desperate for bearing in reply to Jason(ma), 06-17-2005 17:47:49
It takes a 1 3/4' socket
TimS
06-18-2005 05:44:54
 Re: Desperate for bearing in reply to Dick Rogers, 06-17-2005 19:32:50
If you have the part number or can figure the dimensions for the bearing these guys have gotten a couple JD bearings for me that were out of stock at JD, also half the price.
Applied Industrial Technologies
1815 Bedford Rd
Kansas City, MO 64116-4402 Phone: (816) 421-0407 As for the housing, you may have to fabricate one or repair the old if you can't find one at a salvage yard.
Search on google for 'implement salvage', I found quite a few yards listed.
Hope that helps.
