Help! Needles for 224T Baler (long)
jwk
06-17-2005 04:45:02
I"m hoping someone here can provide me with a source for needles for a 224T baler. JD wants $145 each. This model baler seems to be kind of rare.
The long short story is this baler was left to rot under some trees. It was in pretty rough shape, but it has the 30 kicker on it and I was determined to get it working. Paid more than I should have at $500 but the old man insisted they used it 2 years ago (2 meaning 12 probably). A lot of parts, fabrication and 3 months later I baled my first 5 acres. I used the owner"s manual and went over every part to be sure it was in spec.
I had only 6 rows left when the needles broke and I"m almost certain the plungerhead didn"t hit them as I checked the timing again and the head stop and they were fine. The hay wasn"t too tough either.
I believe the problem was in the needle to knotter clearance. Turning by hand the needles did bind slightly at one point in the knotters. Clearances seemed fine so I let it go. One of the needles showed a fracture on the top side just down from the breaking point, I believe this shows that the needles broke forward rather than rearward by the plunger. The plunger would have just broke them clean off too and there would be no other fracture line. After so many cycles they couldn"t take the binding and they broke. Also, walking the field I only found one piece, so I think one need failed before the other as they weren"t together. I also noticed some major rub markes on them.
The baler did work very well. I borrowed my friends much larger late model NH to finish and I could only go 1 gear faster with that. With the 224 I"m running a 4010 in 2nd gear baling doubled up rolls.
Also, I"m looking for an electric thrower adjuster since the manual setup is in poor shape.
Thanks in advance for any leads!
bent
06-17-2005 07:32:51
 Re: Help! Needles for 224T Baler (long) in reply to jwk, 06-17-2005 04:45:02
I have two 214T's sitting in my back 40, both have good needles, would they interchange? I am starting to think they are going to head for a auction or scrap yard, so if you are interested, I will let them go for reasonable used price plus shipping. I am in Prince Albert, Saskatchewan, Canada. Email me if you are interested. Good luck
Bent
jwk
06-17-2005 08:50:27
 Re: Help! Needles for 224T Baler (long) in reply to bent, 06-17-2005 07:32:51
I don't know if they'd interchange. I tried using some from a 24T and they were slightly different. I imagine the 214's would be different as well since it's an older machine.
I'm in Pennsylvania.
Tx Jim
06-17-2005 15:27:39
 24T/224T needles????? in reply to jwk, 06-17-2005 08:50:27
jwk,did you check with Deere to see if #'s are different? I think they will work! Tx Jim
bent
06-17-2005 12:08:44
 Re: Help! Needles for 224T Baler (long) in reply to jwk, 06-17-2005 08:50:27
214 is the same vintage as 224, just smaller, unless I'm mistaken, needles are the same until 336
Let me know if you are interested, make hay while the sun shines!
bent
jwk
06-19-2005 06:19:24
 Re: Help! Needles for 224T Baler (long) in reply to bent, 06-17-2005 12:08:44
Well, the casting number on the 224T needle is AE36262. The 24T number is different.
Can you check what the number is on the 214T's needle?
Thank you.
Sandraw
06-23-2005 20:06:23
 224T Baler in reply to jwk, 06-19-2005 06:19:24
Does anyone know the position the tongue should be in when baling w/the 224T? The manual is unclear to me. WhenI put the tongue in the cneter position the Power shaft is not straight out from the tractor to baler. If I put tongue in the left most position, like it seems the manual says is for transport, the power shaft is straight. What is the correct position for baling?
jwk
06-29-2005 04:03:43
 Re: 224T Baler in reply to Sandraw, 06-23-2005 20:06:23
Sandraw,
I think you have your right and left backwards. The baler's pickup is on the right side. Move hitch towards pickup for transport. For baling move hitch all the way left and pto will be straight.
