shortening the old mower
holcombwa
06-16-2005 20:18:54
Have a '49 Case VAO and got a Case #10 mower last fall. It has a 7' bar and with the native grasses over my 5'10" in the hay field this year, I know the old VAO will run out of grunt. The #10 came in 7', 6', or 5' bar lengths when new. I would like to shorten mine to 5' or maybe 5 1/2. The end looks like it will bolt back on at whatever point you cut it off at. Anyone know of headaches I'm letting myself in for or should I go ahead and oil up the hack saw? Stan
Jerry D in NC
06-17-2005 10:15:37
 Re: shortening the old mower in reply to holcombwa, 06-16-2005 20:18:54
I would give the old VAO a chance before I chopped it up. A sickle does not care how tall the grass is and is fairly easy to turn if properly setup. Alot of 23 hp 8Ns mowed with 7ft bars...
Allan in NE
06-17-2005 06:27:04
Holcomb,
I'd drive over to one side before I'd chop up a good bar.
Allan
Tx Jim
06-17-2005 15:38:23
 Ditto in reply to Allan in NE, 06-17-2005 06:27:04
Ditto to pulling over a little. Tx Jim
Galen
06-17-2005 05:17:26
No worries! B-I-L just did it to his IH, I just did it to a neighbor's JD, Dad did it to his when I was little - common practice. You don't happen to have a manual for that Case #10, do you? Sure would like a copy ..... ... 8^)
holcombwa
06-17-2005 18:19:22
 Re: shortening the old mower in reply to Galen, 06-17-2005 05:17:26
Yep I do. Let me know how to get it to you. Thanks for the info. Stan
