Sickle Bar Rock Guard Adjustment
New Hay Farmer
06-16-2005 09:19:04
What is the best way to adjust the gap between the teeth and the rock guard?
I have a new-to-me NH-47.
Thanks - next hay crop is coming up fine!
Illinois Boy
06-16-2005 13:34:06
 Re: Sickle Bar Rock Guard Adjustment in reply to New Hay Farmer in Indiana, 06-16-2005 09:19:04
Not sure if this is the correct way to do this or not, but here goes. This is how I do it on my Ford 515 sickle bar mower. I cannot say that your NH 47 is made the same way...
The knife teeth should be close to the ledger plates. The ledger plates are flat plates that set in the flat spot (in the grove) on the rock guards and are pinned into place with a pin through the guard. They can be changed out when they wear. (Mine have never worn enough to warrant changing - but that's the idea) Anyway, there are hold down plates bolted along the cutter bar that keep the knife (which the teeth are riveted on) in position which keeps the teeth down close to the ledgers. Sometimes you can hit the hold down plates with a hammer and put a little bend into them to push the knife bar and teeth further down toward the ledger plates - sometimes you must unbolt them and resort to more force to get them to reshape a little. My Dad's JD mower had hold down plates that were just contrary and made of some kind of springy steel - he fought the thing until he bought a disc mower (showoff!!) Just don't over do it - you want the knife teeth to be close to the plates but not in contact with them. If they contact the ledgers while you mow, it won't be long until you'll be replacing teeth along the knife blade.
Like I said - I really don't know if this is the correct way to do this or not, but it seems to work and hasn't flown apart yet!
Ultradog MN
06-16-2005 14:07:43
 Re: Sickle Bar Rock Guard Adjustment in reply to Illinois Boy, 06-16-2005 13:34:06
My Ford 501 manual says that to adjust the guards you do take a hammer and pound them up (or down) as required.
Illinois Boy
06-16-2005 14:52:37
 Re: Sickle Bar Rock Guard Adjustment in reply to Ultradog MN, 06-16-2005 14:07:43
Thanks Ultradog MN,
That's the only way I've ever seen it done - which of course doesn't necessarily mean it's the correct way!!!!!
