Weeds in Seedling Alfalfa
Joe in IN
06-16-2005 07:49:31
Have a newly planted Alfalfa/Timothy field Planted May 8. I'm starting to get some weeds poking up(dandelion, lambsquarter, velvet leaf).
Last year I spayed my field with 24D-B and it worked great. The problem is that you aren't supposed to use the alfalfa for 60 days after spraying. I do follow the label so that puts me into august before getting any hay from this field.
Isthis the best option for a weed free field. lat years planting is basically weed free, it looks great. I hate to mess with what works but wanted to get some hay from the new field before august. What about mowing a little bit? Would that help at all?
Thoughts?
hayman in alberta
06-16-2005 17:32:37
 Re: Weeds in Seedling Alfalfa in reply to Joe in IN, 06-16-2005 07:49:31
the year before we planted our alf/orchord grass I sprayed with round up and the two years before we had barley and used Achieve extra gold and had a clean field. we had a floater put on the seed. I harrowed and packed it. Gave it a light irrigate. Soon we had the nicest field of alf/orchard grass AND THE GREATEST FIELD OF RED ROOT(pig weed). Holy smokes did it look bad. I cut it before the weeds set seed , sold it cheap and took a second cut. Next year 7.1 tons in 3 cuts on irrigation. Beautiful crops since. Don't be sad about the weeds. Cut them early and away you go. Fox tail a different story for another day. Bad stuff!
Jerry D in NC
06-16-2005 08:25:51
I have used a combination of Pursuit and Poast to cover grass and broadleaf weeds. I can not remember the details but I think it was a month or less.
paul
06-16-2005 12:48:11
 Re: Weeds in Seedling Alfalfa in reply to Jerry D in NC, 06-16-2005 08:25:51
Does that work with a grass mixed in as well?
--->Paul
Jerry D in NC
06-17-2005 10:18:54
 Re: Weeds in Seedling Alfalfa in reply to paul, 06-16-2005 12:48:11
Paul,
I do not have the sheet in front of me but the reason we use the POAST is to kill grass. I don't know if the Pursuit weakens or harms it in any way
Jim@concordfarms.
06-16-2005 08:04:18
Joe, I'm in west-central IN. I planted 10 acres of new alfalfa/red clover/timothy/orchardgrass on April 15. Right now the foxtail is about a foot taller than anything else. I can hardly resist the urge to go out and mow it. But I know that if I do, I'll be hurting the young seedlings. I'll wait and cut it around Aug. 1. By then it'll be too late for the weeds to make a serious comeback, but early enough for the young plants to build up food reserves before frost. Then next spring the hay will be vigorus enough to get a jump on the weeds and smother them out. Now, if it was just that easy to control the leafhoppers! Jim.
Allan in NE
06-16-2005 07:58:51
Joe,
This always happens first time outta the chute on alfalfa. Cut 'er a little early and from then on, you are in the chips without the weeds.
Normal operation. :>)
Allan
mike brown
06-16-2005 16:10:39
 Re: Weeds in Seedling Alfalfa in reply to Allan in NE, 06-16-2005 07:58:51
Mowing isn't going to do anything to control the dandelions and they'll only get worse. I think you will have to chose between holding off the harvest or living with some dandelions unless the other chemical choices will work with your seeding.
I personally like to seed in early august after wheat or oats or interseed with the grain but somtimes the seeding hurts the grain crop.
