273 sissal to poly
Stu 273
06-14-2005 12:01:42
New to baling. I bought a NH 273 baler with sissal twine in it already so I used it that way. Turns out my market does not want sissal but poly. I plan to switch from sissal to poly tine this summer.
Its a NH 273, pto driven, manual bale tensioner. Is it possible to just tie in poly and go, or do I need to mess with twine tensioners in the hopper and adjust the knotter?
I am a few weeks from cutting so I want to get ahead.
Steve from New Holland
06-15-2005 04:19:58
 Re: 273 sissal to poly in reply to Stu 273, 06-14-2005 12:01:42
In general, your baler should switch to poly with very little adjustment. However, if you should have a 273 that the knotters were hardly ever worked on and still has the original knife arm and billhook, you may run into trouble. Under the assumption that the knotters have been worked on over the years, you should be good to go. One thing though, loosen the tension on the clamp that is mounted on the side of the twine box. It's hard to describe how much to loosen, but the tension MUST be less for poly twine then for sisal twine. Steve
