What does it weigh
IronHorse
06-14-2005 11:02:25
What is the weight on an AC 60/66 allcrop combine?
I need to tow to my place and there are a few ups and downs. I am more worried about the downs the n the ups. I have a ford F250HD will this get the job down if I take it easy.
Thanks for all your responses
Doug in IL
06-14-2005 13:51:25
 Re: What does it weigh in reply to IronHorse, 06-14-2005 11:02:25
They are right at 3000 pounds.
old
06-14-2005 11:37:45
You shouldn't have any problems with that, just take it slow and besure to leave a lot of run between you and the car ahead of you. Shot I pulled a NH 460 mowco behind my geo tracker and pulled it 100 mile. Don't get me wrong I would not reccomd doing that but I needed to get it home and that was all I had at the time. Also don't drive to fast and check the wheel bearings before you leave with it and make sure they are greased up real good
old
06-14-2005 11:37:08
old
06-14-2005 11:36:36
You should have any problems with that, just take it slow and besure to leave a lot of run between you and the car ahead of you. Shot I pulled a NH 460 mowco behind my geo tracker and pulled it 100 mile. Don't get me wrong I would not reccomd doing that but I needed to get it home and that was all I had at the time. Also don't drive to fast and check the wheel bearings before you leave with it and make sure they are greased up real good
