hay moisture
lloydga
06-13-2005 04:28:32
what is the per cent of moisture in bermuda grass hay that it is safe to bale at?
txgrn
06-13-2005 08:33:04
 Re: hay moisture in reply to lloydga, 06-13-2005 04:28:32
I do the 3 turn twist and break. Works for me.
Grab a handfull bout half way down. Put hands together (index fingers and thumbs touching) around wad of grass. Twist like you would do if turning a hand drill (brace). If it pops on the 3rd or less turn, go for it.
Mark
Roper6365
06-13-2005 13:46:04
 Re: hay moisture in reply to txgrn, 06-13-2005 08:33:04
You know everyone on this board is going to try that, Including me lol...
That answer is why I don't ask my father anything because he'd give me an answer like that and be right, then tell me to take my 300.00 moister checker back for a refund. :)
txgrn
06-15-2005 06:52:12
 Re: hay moisture in reply to Roper6365, 06-13-2005 13:46:04
Don't laugh man. I have been here 25 years and that was the way it was done when I got here....still done that way.
Also we don't sell by the ton; by the bale. Maybe we are lazy or cheap, but that's how it's done and we bale a lotta hay and feed a lotta live stock. I know there is a ton of variables but the biggest is moisture and that can throw you for a loop.
So to do it the other way you gotta get an accurate moisture gauge that has been and has been kept in calibration. Have to determine what time if day it is as the moisture will change drastically from noon to 5pm. Have to truck the hay to the scales and back, interrupting your hayin operation....and on and on.
Then the hay you put in the barn at 18% or whatever moisture and 65#'s has sat there for 6 months and now you have a customer that wants to buy it but it now has 10% moisture and the weight is down to 45#..... .grrrrr rrrrr . Like my (our) way better.
Not knocking the way some of you guys do it.....just telling it like it is around here.
Go for it.
Mark
roper6365
06-15-2005 16:19:34
 Re: hay moisture in reply to txgrn, 06-15-2005 06:52:12
Mark, you are very right, I do use the tester most of the time but My dad won't touch one. The % does change of course and some Horse folks are very picky so timing is everything. I try to sell all of the first cutting right off the wagon because in the middle of winter when there is almost no moister the bale weighs 10lbs less and most people know that so .50 cents per bail is down the drain. My dad has been cutting 200 acres for horse hay as long as I can remember and he is so old fashion that I can't stand it somtimes but I don't knock it because he still makes better bales than I do :)
