Tedder or Inverter?
M Nut
06-11-2005 07:12:45
I am going to have a heck of a time drying hay this summer. I have clover and orchard grass like never before. It rains every other day, and I have not been able to start cutting hay yet. I know I'll need something to get this hay to dry when I can finally get it cut, but don't know which is better for my needs? Has anyone had much experience with either one? The tedder I'm looking at is a John Deere 4 pod model 756, and the inverter is a New Holland model 166. I need some professional opinions, and knew this was the place to come. Thanks.
M Nut
06-11-2005 19:40:43
 Re: Tedder or Inverter? in reply to M Nut, 06-11-2005 07:12:45
Thanks for the opinions. I opted for the tedder. Seems to be the best choice. I do have a New Holland 258 rake, so if it just to turn the rows, I decided that will work. When I need them scattered thin, seems only a tedder will do that job. Now the weather just has to straightn out so I can put this little thing to use.
Fern(Mi)
06-11-2005 16:32:43
Aside from loving my wife more than our equipment we have the whole menagerie of haying implements around here.
What I don�t see mentioned is field conditions. We have some hilly well drained ground. We�ve some low water holding fields (might have made rice paddies) that just never quite dry out enough. And of course some fields that drain, lay or slope just right, haying is a delight, with weather�s cooperation of course.
Have found semi-wet condition�s easier to deal with when I have a dry place to turn the hay too for a wee bit more drying spell for same day bailing. For this I�ll use a coveted old AC pto driven hay rake (two speed forward plus a tedder reverse) behind a fast idling WD45 in third gear using the very left end, just outside the left driver, to just up that windrow onto the drier ground between those same soggy under-sided windrows.
Those fields well drained have used the inverter with good success to bring the wet bottom side up to dry. Exceptionally easy on alfalfa hay leaves. The preferred implement of choice for all second and third cutting alfalfa.
Haven�t had much luck with the tedder feature on that old AC hay rake. Just as soon use either the previously mentioned implements as described.
Almost last, when its only grass, we�ve a sorryly worn out five beater IH hay rake I�m a-feared to take apart, so I just keep pouring the lube in the gear-box as needed.
Now, lastly our covering 600 acres, we use a hay-conditioner windrowing almost every thing. Las time I broadcast the cutting was six and seven years ago when I would have sworn we were harvesting kelp. Between WD45 and a 951Ford raking fuel most likely comes to less than forty gallons gas.
So, there's my slants on raking hay.
Fernan
Sid
06-11-2005 16:31:10
We have had very good results with a tedder in heavy clover and orchard grass also with alfalfa. We have cut with haybine in afternoon ted as soon as soon as dew is gone the next morning and baled that afternoon. We do not do it every time. I would just as soon save the extra trip if possible. A tedder has helped us many a time get hay in when we did not have the weather we wanted.
Fern(Mi)
06-11-2005 16:26:29
So, there"s my slants on raking hay.
Fernan
roper6365
06-11-2005 12:58:51
I like the tedder myself. But come July when the weather clears a bit i'll just rake it a few times. I'm dealing with the same weather here in N/E Pa so if ya wanna get the hay in the barn in two or three days " if the rain holds off that long" you need to ted it.
Good Luck, Roper
ejr-IA.
06-11-2005 10:36:13
Same here in western IA.rain,rain and more rain.Have some 1st cutting still in the windrow from monday turned it wed. just to keep it from getting moldy rained every day since.Too keep my leaves I have a two and a three wheel rake or hay turner at the right speed it will turn the windrow over once without beating it up.The two wheel for small windrows the three for larger ones.
A-farmer(not)
06-11-2005 10:14:23
A mower-conditioner kinks the stems which allows for faster drying. A tedder works great;it really helps dry,everyone around here has one. A baler with preservative injectors will allow you to bale hay with a higher moisture content. When working in your hayfield and clouds come shake your fist and swear at the sky while pleading with your gods for sun.
RAW in IA
06-11-2005 09:48:51
Years agop when we needed to roll the windrow over we just used the hayrake . Had to be precise on where to drive but it will work.
Stan (NCMO)
06-11-2005 07:47:17
I have the same problem, I think its rained every other day here, I'd like to see an answer to your question very much.
