Looking for 6 used tractors, or maybe a quick hitc
snappie
06-10-2005 20:04:21
this changing 3 pt equipment all the time is a pain in the a$$. I am to darn old to be do"in it. I guess I need a 1/2 doz more tractors. I"ve seen a lot of those quick hitches in catalogs and at farm sales. are they any good?? your opinions
msb
06-11-2005 17:40:18
 Re: Looking for 6 used tractors, or maybe a quick in reply to snappie, 06-10-2005 20:04:21
They are not perfect but are a lot cheaper and a WHOLE lot less maintenace that a half dozen more tractors.Lets see ;6 tractors, that means 3 new batteries plus 4 or 5 flat tires each year.Naw, I would buy the quick coupler "AND" a center link cylinder.The center link cylinder will go a long way to eliminate the problems a quick coupler causes.I wonder if the neighbor still has mine?Its been gone for about 10 years.He must like it,huh?
Hugh MacKay
06-11-2005 13:09:29
snappie: Some hitches are user friendly and a good many of them are not.
snappie
06-11-2005 12:10:12
I"m thinking 2 Ford, NH, 5610"s, 2 Ford NH 6610"s, 2 Deere 2555"s and 2 Deere 2755"s. what do you think?
txgrn
06-12-2005 07:43:40
 Re: Looking for 6 used tractors, or maybe a quick in reply to snappie, 06-11-2005 12:10:12
Must have very deep pockets my man.
Mark
old
06-11-2005 07:51:01
I have 4 tractors out in the field right now because I don't like to hook up and unhook as needed, plus others sitting in standby just in case onhe brakes down.
old
06-11-2005 07:50:27
txgrn
06-11-2005 04:53:12
You laugh. I'm up to 7 right now.....for that reason, sorta.
Mark
paul
06-11-2005 03:46:59
Pto & hyd hoses need adjustment. Many implements turn out to be slightly off-standard in dimentions, esp. that upper link so some modifications or machinery trading needs to happen. For big heavy implements it will move the load back a couple of inches, makes your hyd work harder/ lowers lift capacity/ makes front end even lighter. Does not work with specialty equip such as post hole diggers, backhoes, etc. so if you use these you end up taking hitch off & on - more work.
After all that, once you get settled in they work well & save time. Just depends on what exact implements you use & how standard they are.
--->Paul
Tx Jim
06-11-2005 03:17:44
snappie,if you are just using one category size equip. they help,but the heights of center link masts on diff. equip. are not all the same so some adjustments may be in order.Tx Jim
