Hydraulic top link for a 3-pt hay fork
Flying V Ranch
06-08-2005 19:27:46
I'm thinking about building a new 3-pt hay fork. My tractor is a Case 1070. The big ole lift arms reach up pretty high and I was thinking that with a hydraulic top link to extend and level the bale I could easily back up to my trailer and load bales from the sides of the trailer. (I have no FEL on this tractor.) Has anyone done this before? Any construction advice? I have looked on the net and saw pictures of elaborate fork lift type setups, but that is way more than I need for this type of job. I like simple stuff in the field. Can someone give me the specifics of what size and type of hydraulic cylinder to buy? Thanks in advance folks!
JiminIA
06-09-2005 19:06:45
 Re: Hydraulic top link for a 3-pt hay fork in reply to Flying V Ranch, 06-08-2005 19:27:46
We made out stuff we had layin around about 10yrs ago. standarf hyd, cyl then we used a couple of ball sockets of off some bust 3pth linkages, drilled a 1" hole in them to mount on the cyl., then used the end w the ball on the tractor and the implement worked good..jim
Mike in Houston
06-09-2005 06:03:48
www.baileynet.com has them.
They have a downloadable catalog.
mee
Indydirtfarmer
06-09-2005 03:01:51
Do a websearch for "Sweet Farm Equipment" in Camner Kentucky. Contact Ken Sweet... They have a factory made CAT II 3-point top link. It has a built-in check valve that holds position when not under pressure. Nice piece. It sells for $265 and frieght. Tell him John sent you!
Hay Dr
06-09-2005 06:24:54
 Re: Hydraulic top link for a 3-pt hay fork in reply to Indydirtfarmer, 06-09-2005 03:01:51
third party image
CCM has the CAT 1 & CAT 2 hydraulic toplinks in stock. Welded cylinder construction- Double Piloted check valves for safety and position stabilization.- CAT 1= $175 CAT 2= $225
edchainsaw
06-08-2005 20:44:59
my neighbor has 2 of those cylinder 3rd arms. he loves them.. ( not for hay anymore)
he baught his already made.
edchainsaw
06-08-2005 20:44:22
