JD 290 Planter problem
Keez
06-08-2005 18:12:27
I bought a 290 planter last year and it has worked ok, but it developed a problem which has gotten worse until now it won"t work. When I pull the rope to engage and raise the planter, it starts raising then abrubtly drops back down making it impossible to trasport and turn around. It keeps going through this cycle until after a while it might latch or might not. Any ideas. I"ve jacked it up and tried to watch the mechanics of it but can"t figure out what is not working to make it stay latched.
Leroy
06-08-2005 18:48:01
 Re: JD 290 Planter problem in reply to Keez, 06-08-2005 18:12:27
either too much grease or dirt or broken spring
J.C. IN AZ.
06-09-2005 22:18:33
 Re: JD 290 Planter problem in reply to Leroy, 06-08-2005 18:48:01
Check the Spring on the Lift Pawl. If broken replace .
