Hi, A few teething problems by the sounds of things! i opperated a vermeer 504 silage model, so i guess it would be much the same. 1. From what i can remeber, the whole twine tying mechanisinm can be adjusted for height, by bolts on either side of the baler, the tubes need to be about an inch below the starter roller. 2. unlaching of the back door is caused by pressure loss in the cylinders, switching the locking device on cures the problem, it would indicate a leeky connection at the tractor end, maybe adjustment needed on spool block? 3. are the ovel ejector plates installed? these are fitted over the bottom roller. We baled 15,000 bales a year with the old and we never switched the pto off when ejecting the bales, yeh, yeh, yeh, i know the book says to stop p t o when ejecting but, it actually worked better by leaving the pto going. 4. I cant really help with the last bit, we had hydraulic tensioning and one spring each side, the was the option of extra springs but bale density was never a problem! Hope this helps Alan
