NH 469 wobble box
Kelly C
06-08-2005 05:25:35
Whats the maint procedures on this. Says nothing about the wobble box in the user manual. Sure there is some bearings in there.
grub0927
06-08-2005 16:00:05
 Re: NH 469 wobble box in reply to Kelly C, 06-08-2005 05:25:35
If you have to replace bearings, the outer races are hard to drive out because of the angles. Run a bead of weld on the race and let it cool and it will fall out. Some things a kid never forgets!
Good luck
Our Farmer
06-08-2005 05:49:53
My understanding is grease, grease and more grease. There are 4 zirks, and I grease mine after every use. Once they start to make a knocking noise, you've got trouble because according to a forum search I don't believe they can be rebuilt. How'd that pickup cam bearing replacement go on your baler?
Kelly C
06-08-2005 05:59:46
 Re: NH 469 wobble box in reply to Our Farmer, 06-08-2005 05:49:53
I grease the heck out of those 4 zerks every time.
I just cant see how grease from the zerk behind the wobble gets to the bearings in the Hub assembly.
Bearings on the yoke are ok.
Oh I bet I could rebuild one on a 469. Looking at the parts book, its just 6 bearings to replace.
Other than going at a strange angle. It looks just like a regular wheel hub and axle.
I didnt replace the cam on the 68. I got a big hammer and a steel pipe and knoked that dent right back. Cam is strait now.
The whole thing still needs to be replaced as the pipe holes are all wore out.
But can get one more year out of her now. I will remove the pick up next winter and switch out the pick up. Not looking forward to that at all.
Steve from New Holland
06-09-2005 04:21:20
 Re: NH 469 wobble box in reply to Kelly C, 06-08-2005 05:59:46
Kelly, trust me, the grease is going to where it is needed most. Also, I concur, grease, grease, and more grease. Steve
