International 46 baler Needles
Hogman
06-06-2005 19:43:46
Every time I have tried to use this baler it snaps both needles...I have had the needles welded 4 times now..I got it ready for the field today.i baled 10 bales of loose hay in the barn and on the 11 one they snapped again..... .It makes a really nice bale I hate to get rid of it...Does anyone know what is wrong????? ?????I am so fed up....Scott
ejr-IA.
06-09-2005 19:24:37
 Re: International 46 baler Needles in reply to Hogman, 06-06-2005 19:43:46
Doesn't your plunger stop work you better check it out.
Ks-farmer
06-07-2005 14:49:16
I have a IHC 46 baler that is complete and would like to get rid of it. The only thing that is wrong with it is it sat outside and the plunger is locked up. I would like $50 for the whole baler.
jim81401
09-17-2006 14:41:37
 Re: International 46 baler Needles in reply to Ks-farmer, 06-07-2005 14:49:16
Do you still have your #46 baler? I need a knotter assembly or some place that still have parts for this baler.
Hogman
06-07-2005 18:56:20
Where are you located Ks??Email me
paul
06-06-2005 22:38:50
As Jim says below, your baler is out of time, or the needles were not perfectly welded. They really need to be about perfect.....
As to the timing, chain stretch can mess things up, buy a new chain, set it up to spec on the timing. Anything else go loose on the whole timing driveline, some key or clamping bolt or some such?
--->Paul
