PLEASE HELP IDENTIFY
TONY KIGHT
06-05-2005 16:31:01
I RECENTLY BOUGHT A TRACTOR AND NEED HELP IDENTIFYING THE YEAR MODEL. IT IS A INTERNATIONAL 350 UTILITY. THE BEGINNING SERIAL NUMBER IS 114.
burnetma
06-06-2005 19:54:04
 Re: PLEASE HELP IDENTIFY in reply to TONY KIGHT, 06-05-2005 16:31:01
If it has a white grill it is 1957 or later. Red grill is pre-1956.
Why do you need to know the manufacture date?
Hugh MacKay
06-07-2005 13:07:35
 Re: PLEASE HELP IDENTIFY in reply to burnetma, 06-06-2005 19:54:04
The white grill indicates very litte anymore, large numbers of earlier tractors have been repainted with grill white 100, 200, 300, 400, etc. Yes, I've even seen letter series tractors with white grills.
Casting codes are the way to go if serial number doesn't tell you anything.
Hugh MacKay
06-06-2005 02:33:41
Tony: If it is a 350 IH serial numbers started at 501. You must have another number. Go to left of this page, to Research & Info, click on serial numbers, then Internalional then I-350. It has to be 56, 57 or 58.
Tony Kight
07-01-2005 17:34:16
 Re: PLEASE HELP IDENTIFY in reply to Hugh MacKay, 06-06-2005 02:33:41
Thanks for your help. The only numbers I've found on the tractor are 448511 located on the steering arm, 1108041 located on the starter, and C-175 loscated on the motor. For what it's worth, it does have a white grill. I'm trying to get parts for it and can't until I find out year model. Any help greatly appreciated!!
