Massey Ferguson Sickle Mower
John17
06-05-2005 15:47:16
I have an old MF sickle bar mower, that works fairly well, except it always wants to plug at the end of the bar. Should it have a half section on that end or is there something that is adjustable. I don"t know what number MF mower it is, but it is a three point setup, without a pitman arm. Thank you JohnG
farmer jim
06-11-2005 15:44:31
 Re: Massey Ferguson Sickle Mower in reply to John17, 06-05-2005 15:47:16
Does the MF 451 sickle bar drop below ground level for mowing pond and ditch banks? thanks
Countyman2
06-06-2005 14:11:21
John Does the far end "boot" have a ledger plate against which the blade can cut, as all the fingers have.
I am pretty sure that it should have a full section on the end of the blade, the end shear face cuts against the ledger plate in the end "boot" Does the tip of all the cutting blades go exactly in the centre of a finger before returning ?
John17
06-07-2005 18:20:59
 Re: Massey Ferguson Sickle Mower in reply to Countyman2, 06-06-2005 14:11:21
This gives me something to check into. I have not checked to see exactly where everything ends up on the stroke. How do you adjust the bar if it does not hit the center? I thank you all for the replies. JohnG
Indydirtfarmer
06-05-2005 15:57:29
Odds are it's a model #41 "DynaBalance". They were made by Vermeer for MF. GREAT mower when it works.... Yes is should/does have a half-section at the end, I've had a couple of 'em. With correct adjustment, they are cuttin' machines....
John17
06-05-2005 18:29:51
 Re: Massey Ferguson Sickle Mower in reply to Indydirtfarmer, 06-05-2005 15:57:29
I am sure they are a very good mower, but it is the proper adjustment that has me puzzled. I don't see anything to adjust at the end of the sickle. I bought this machine last year, and haven't really had a chance to use it until today. The first thing that I noticed was that it did not have a half section on the end, but I don't see where that would cause the problem with plugging that I am having. Thank you for the feedback. JohnG
edchainsaw
06-05-2005 21:25:59
 Re: Massey Ferguson Sickle Mower in reply to John17, 06-05-2005 18:29:51
I used one of those as a kid.. and have a diffrnt one that Idont use now.
there are adjustments as all sickle types knives have... but it has to have a double knife at the end..
