drilling beans
Kerry Florence
06-05-2005 11:19:49
I have an 8350 JD drill, what setting should I use for soybeans? How fast? Thanks
JMS/MN
06-05-2005 20:05:10
 Re: drilling beans in reply to Kerry Florence, 06-05-2005 11:19:49
Setting depends on how many bean seeds per pound of seed, and what population you want. All those details and combos are in the operator manual. I can check mine tomorrow and give you an idea, but there are dozens of combos. I would generally seed about 1 1/2 bu per acre with a grain drill, looking at 160-175000 seeds per acre. Speed of 5+ mph should be ok with that drill. Easy to drill 7 acres per hour with the 13 foot.
JMS/MN
06-06-2005 08:54:20
 Re: drilling beans in reply to JMS/MN, 06-05-2005 20:05:10
Here are some details from the manual- Fluted feed, six inch row spacing, lbs of beans at notch settings 12-16-20-24 are thus: 61-92-127-163. Set the feed gate in position D or E, these rates are for slow speed drive setting. I would guess these settings are for beans at about 2300 or 2600 seeds per lb. Tire size is another factor, along with all the other row spacings, etc. that these drills were made to. That's why you need an operator manual. Each year provides only only chance to plant right. Whatever you start at, monitor seed usage vs. the acre meter to determine if you are getting the right amount into the ground.
