John deere # 30 ejector problem
Mark in Wis.
06-03-2005 05:34:40
My 336 baler works fine but when the ejector trips, the bale barely makes it over the front of the wagon. I've made all the adjustments suggested in the owners manual with no success, called my dealer, he suggested to make sure the shear pin was not sheared and that the belts on the pump were tight. I asked if the control valve or the pump could be the problem and he said that very seldom are these bad. Does anyone have any suggestions on what to look for? Thanks. Mark
Dave Sherburne,NY
06-04-2005 10:48:14
 Re: John deere # 30 ejector problem in reply to Mark in Wis., 06-03-2005 05:34:40
Thats what mine was doing . New belts new filter and it worked fine yesterday . Several bales over the back of the wagon. The old belts were worn to narrow, and were riding on the bottom of the groove. Put them on tight.
Farmer Gene (NW WI)
06-03-2005 07:14:38
The baler slip clutch needs adjusting or it may need a new clutch lining, it"s located at the front of the baler where the pto shaft ends.
