New Idea 30A Mower
Vaughn
06-03-2005 05:24:47
I have a New Idea 30A mower that I use for mowing some pasture. It has a mechanical rope trip lift mechanism and a spring broke that returns the lever that is pulled with the rope. Without the spring, the bar keeps cycling up and down.
Some pictures are here : http://home.messiah.edu/~vmiller/mower/mower.htm
Any ideas on fixing this, or where parts might be obtained?
Thanks
Vaughn Miller
Dillsburg PA
hdlong
06-03-2005 08:25:38
 Re: New Idea 30A Mower in reply to Vaughn, 06-03-2005 05:24:47
I have had 3 or 4 of these mowers and the band spring was still available a yr or two ago. But you can take a screen door spring and go over top of gear houseing attach one end to bolt that hold houseing cover on in the back and go over top and attach too hole in trip arm where rope goes this will hold tension on arm so brake can stop when arm cam rotates. I also have a model 30A for sale in Ohio
Michael IN PA
06-03-2005 06:12:28
Small world! I live near Heidlersburg :)
If you have to have a NI spring, then did you try Yingling's in Gettysburg? They might have a NI 30A for parts. Or start calling implement dealers in Lancaster county -- I bet that mower is still popular there.
But I would bet that you could find another spring close in size and tension that would work. Tractor Supply has assorted springs, as does Martin's hardware in New Oxford.
Good luck,
Michael
Vaughn
06-03-2005 06:55:49
 Re: New Idea 30A Mower in reply to Michael IN PA, 06-03-2005 06:12:28
The spring is curved flat spring steel, so it would not match up to standard hardware items.
Thanks for the suggestion of Yingling's
Vaughn
