# of bales twine vs wire
Tx Jim
06-03-2005 03:36:39
How many bales can a body bale with two spools of twine.Granted I think twine comes in different length balls and I know one can bale around 750 bales with 2 boxes of wire.I'm just trying to figure difference in cost of each.Also what wire balers that are adjusted correctly leave little short pieces of wire in bales????? Thanks,Tx Jim
Roy B
06-04-2005 17:35:18
 Re: # of bales twine vs wire in reply to Tx Jim, 06-03-2005 03:36:39
Jim;
I seem to get right around 500 bales per box using 10 000 sisal. Roy
RickL
06-03-2005 16:15:13
I been running the 7000 in single ball. I get around 850 bales. Has anyone run a agway large bale unroller. doing more and more large round baling into small square.
kyhayman
06-03-2005 15:23:50
I get about 550 out of 10,000 sisal, 505 or so out of 9000 plastic. Depends a lot on bale length. I went to 36" bales 2 years ago from the local standard 38" as I increased bale density.
Jerry D in NC
06-03-2005 08:20:38
The math of a 16X18 bale that is 3 ft long says you would need 8 3/2 ft of twine per side. Each bundle of twine (two balls to the bundle) has 9000ft in it. Work it out and you get that it will do around 500 - 520 bales per bundle. Alot of factors can change this but that is a rough estimate...
paul
06-03-2005 05:30:58
Which strength of twine? I get round about 500 bales out of a set of 9000 sisal, depends on lots of variables of course.
--->Paul
Joe(TX)
06-03-2005 05:06:27
You could divide the number of feet in a ball of string by the feet in a box of wire and multiply by 750(number of bales). Gives the approximate number of bales with string.
Tx Jim
06-04-2005 04:03:12
 Thanks to all in reply to Joe(TX), 06-03-2005 05:06:27
nt
