Pick-up frame conversion
Galen
06-02-2005 19:31:02
I have an extended cab 1974 Dodge pick-up frame in the pasture. Everything is there and all the moving parts still move. How hard would it be to build a hay rack out of this? I have a tounge and lumber, but need ideas. Thanks!
Randy-IA
06-03-2005 21:00:11
 Re: Pick-up frame conversion in reply to Galen, 06-02-2005 19:31:02
Hi , I don't know how to do it either but it seems as it all boils down to getting the steering just right with the tongue pivot . Other than that I guess just build the frame sections up till you have a low but level platform , bolt both ends down since you'll have the trucks suspension doing the flexing instead of the reach , and weld bolsters on the outside of the stringers to bolt to which will also help keep everything in line . I've thought of doing that too . A local welder has frames that he moves tiling rigs on that he builds , works for him . Good luck with it . ...Randy
