JD 4 Bottom Trailer Plow
Richard Fazio
06-02-2005 12:24:29
I've got a JD plow and I bent one of the shares away from the moldboard. I looked at it and see that it was repaired before and not very well. The mount that holds the entire assembly to the frame is messed up. From what's left of the model number on the plow and it appears to be an F560H, or F56??. I'm hoping one the John Deere guys know if there is such a plow and If I can get parts for it.
Here is a picture of it when I was stuck in the mud.
third party image
Here is the Number.
third party image
Leroy
06-02-2005 17:56:03
 Re: JD 4 Bottom Trailer Plow in reply to Richard Fazio, 06-02-2005 12:24:29
That plow should have the blade (Throwaway) share and there are hundreds of those bottomes out there in the parts yards, any plow up to the metric with blade share as long as it is corect bottom size should fit
Richard Fazio
06-03-2005 05:40:34
 Re: JD 4 Bottom Trailer Plow in reply to Leroy, 06-02-2005 17:56:03
Wow that sounds good. I was worried I would have trouble getting it going again. I works really well once I got it set up. Thanks for the info Leroy.
