What PTO speed for Gehl 2340 mower
mud
06-01-2005 13:23:54
Looking into a discbine close to here.
RickB
06-01-2005 13:50:49
 Re: What PTO speed for Gehl 2340 mower in reply to mud, 06-01-2005 13:23:54
Could be either 540 or 1000 depending on how it is set up and what input shaft is attached. if i remember to change input speeds, a gearset in the gearbox is reversed, and the correct powershaft yoke is fitted.
mud
06-01-2005 13:53:34
 Re: What PTO speed for Gehl 2340 mower in reply to RickB, 06-01-2005 13:50:49
Thanks RickB- What would you say a fair price is for a moderatly used one? Anything to be aware of?
mud
caseyc
06-01-2005 14:18:50
 Re: What PTO speed for Gehl 2340 mower in reply to mud, 06-01-2005 13:53:34
check the discs for bearing play! i have an older DM160 model and i got it chaep cause a few bearings were bad. when i went to replace bearings i found out why it was so cheap! between the labor to put them in and the cost of the bearings i could have bought a good one. i saved some money by doing it myself but it was still labor intensive. required two guys or if you have an overhead hoist you could probably handle it yourself.
casey
