How sharp?
Dug
05-31-2005 21:19:48
How sharp do you want the blades on a finish mower? I have been told to leave a blunt edge as a sharp edge will chip the blade if you hit a rock.
Second question, while sharpening with an angle grinde while the blades are still attached, do you worry about the top side of the blade, or only grind on the bottom?
Dug
brian 1
06-01-2005 08:18:04
 Re: How sharp? in reply to Dug, 05-31-2005 21:19:48
Finish mowers should be sharp, brush cutters are better with a bit of a blunt or rounded edge.
Vern
05-31-2005 21:30:11
I've never heard of sharpening the bottom of the blades, only the top. The bottom should be flat.
Vern
Pooh Bear
05-31-2005 22:56:53
 Re: How sharp? in reply to Vern, 05-31-2005 21:30:11
You don't sharpen the bottom.
I have also heard not to sharpen them to a razor edge.
I still try to get mine sharp as I can tho.
And you should take them off and balance them when sharpening.
Pooh Bear
Pooh Bear
05-31-2005 22:56:41
Pooh Bear
