IH plow #PO17184
Tonya
05-30-2005 08:45:11
I would like to know if anyone could help with information on this plow. It has rubber tires and is a two bottom pull type trip plow. It looks like it had a t one time red and blue paint on it and white rims. I was wondering if this is a Little Genius? Any info and parts availibilty such original looking tires would be great. It ha BFGoodrich knobby tires on it. Thank You, Tonya
Chris in SeMo
06-03-2005 17:42:30
 Re: IH plow #PO17184 in reply to Tonya , 05-30-2005 08:45:11
Tonya,Just stepped outside to check my Little Genious saw the part number PO 17184 on the shortest beam and PO12572 on the long beam so you probably have a little genious.Mine has IHC insignia stamped in front of every part number that starts with PO. Hope this helps,Chris in SeMo.
Tom ohio
05-31-2005 21:15:21
I have a 14 inch two bottom trip plow with the #sPO23408-front and PO23402A--back. I have been told the P and O stand for the part #s of the PO Plow Company that made McCormick-Deering plows and was finally bought out IH. I was told mine is McCormick-Deering #4 Wonder Plow. See posting from april 30th under Help Identify. Good luck.
Tonya
05-30-2005 18:37:11
Please semd me your email address and I will send you pictures of the plow
Hugh MacKay
05-30-2005 17:54:47
Tonya: The number you have included in title is a part number. Can you tell me what part of plow it is from. I briefly looked through parts list for both Little Wonder and Little Genius plows. There is quite a long list of part numbers, thus makes it quite difficult to find. If I knew that part that number came from, it could narrow it down quite quickly.
Does you plow have a rear tail wheel and is that wheel fixed or does it lift back of the plow?
