Still looking for a wagon hub by EWC #Q415
Walter
05-30-2005 04:27:06
Still looking for a hub for my wagon. Needs to be an Electric Wheel Company hub with part number Q415 cast on the back. Will also have EWC in over lapping letters cast on it. These were fit on a varity of wagons. Mine is on a Sears (David Bradley). Also were put on Cobeys, Wards, and some plows, rakes, and seeders.
Walter
Don-Wi
05-31-2005 21:22:19
 Re: Still looking for a wagon hub by EWC #Q415 in reply to Walter, 05-30-2005 04:27:06
Try Shoup. If you have the measurements you can probably find one that works in their catalog, or maybe online. I can't help on an original, but it may be worth a try. They have 4, 5, and 6 bolt hubs.
Donovan from Wisconsin
ohjeffoh
05-31-2005 09:55:13
here's one on ebay, could it be the same? it's about 15 miles from me. Link
marlowe
05-30-2005 19:57:23
OK then try LAKESIDE FARM IMP. 1-800-365-4863 40 acers of parted out imps. what state you in?. ask for tunis when you call
Walter
05-30-2005 18:34:05
 Baum does not have these. in reply to Walter, 05-30-2005 04:27:06
I am going to need one that matches the others for a restoration. Guys please look around and see what you can find. This is a 5 lug bolt hub with a dust cover held on by 2 screws coming through the sides near the base.
Walter
marlowe
05-30-2005 17:27:49
call BAUM 1-800-228-9222 they should be able to fix you up
SHeiserman
05-30-2005 07:09:53
I bought a 6 bolt (6" circle) hub for an 8 ton Wards through Midwest Wheel. A new spindle and complete hub ran $51. It wasn't an EWC hub, but it was a new matching set- no muss, no fuss. IF you're interested in going that route, the Des Moines # is 1-800-785-3705, or maybe try www.midwestwheel.com.
