farmhand bale accumulator
steve nd
05-28-2005 12:18:44
I have a farmhand f100c accumulator. Can I forget the hydraulic pump and run it right off my 4430 hydraulic system??
BobMo
05-28-2005 21:24:49
 Re: farmhand bale accumulator in reply to steve nd, 05-28-2005 12:18:44
I'm not sure what the volume is on a 4430 but I�m sure it�s high enough to run the accumulator. I run mine with the independent system, as the tractor I use for baling doesn't have the volume needed. If you can use the tractor hydraulics� it of course eliminates the need for a reservoir. You'll need about 14 gpm. Good luck...
