MH 62 Plow
Jerry (AL)
05-26-2005 19:19:58
I posted this a while back. I have a MF255. The hitch points on the plow for the lift arms is so narrow that you can just see the edge of the pin hole. The MF can accomodate either a cat I or II plow by rotating the balls.
The question is modifying the beam to give me a wider space. The question is do you just grind away at the shoulder and use it as a cat I or do they make somthing that might slip over the existing shape and weld into place. I'm sure that some of you have run into this with some of the older plows.
