cyclo 400
fireman3
05-25-2005 20:17:05
does anyone no what the air pressure gauge is to be at while planting. also which spockets to place 200lbs fertilizer to the acre
James2
05-26-2005 19:50:42
 Re: cyclo 400 in reply to fireman3, 05-25-2005 20:17:05
The fertilizer question is more involved. I assume you have the high rate auger and are planting 30 inch rows. There are also low rate and extra high rate augers. The low will not get up to 200 lbs/acre, and the high rate will not go that low. Look on the right side auger as looking from the rear of the planter. The inside auger section should be a 472424R1 for the high rate. The low rate is 472420R1. Extra high rate 483533R1. The chart shows an 8T driver sprkt and 15T driven sprkt for 190 lbs/acre. The next closest is 230 lbs/acre using a 12T driver and 18T driven. As stated earlier, this is for 30 inch rows and high rate auger.
Allan in NE
05-25-2005 21:33:25
Yep,
9 ounces pressure minimum to 11 ounces max.
Allan
Gerald J.
05-25-2005 21:06:23
Best I recall, at least 9" pressure. Less than that and it might not plant at all. Mine did that, its no longer in use. You will probably have to swab out the pressure equalizing hose from the drum to the seed tank and tighten up the seams around the middle of the seed tank to get pressure high enough.
The herbicide/insecticide boxes won't do any where near 200 # of fertilizer to the acre. I don't have any other fertilizer attachment or books so I can't say.
Gerald J.
