Stuck Bale (Ford 532 baler)
Illinois Boy
05-24-2005 09:25:56
Hi all,
I've never used a square baler myself, only round balers, but couldn't pass up a deal to get a Ford 532 - the price was very right!!
The baler works great - on all sizes. My problem is the last bale that's tied gets stuck in the chute and I have to cut the twine and remove it flake by flake. Even loosening the tension adjustment all the way does not help remove the stuck bale. I thought maybe the hay might be a little to damp. Does anyone have an idea of what could be the problem?
Gregg
05-24-2005 23:27:53
 Re: Stuck Bale (Ford 532 baler) in reply to Illinois Boy, 05-24-2005 09:25:56
If the baler is stored outside, I would recommend removing the bale so it doesn"t act like a wet sponge.I store my MF9 outside but with a pickup cap covering most of it. After use I clean and oil the chute and the next season we are good to go.
John In Iowa
05-24-2005 20:45:07
Illinois Boy,
You could use straw, but that sounds like more work to me. If you just starting the season your press may not be shined up good yet. I have an IH 46 and I cover everything with oil before I put it up for the year. It sat in a dealers lot for 2 years before I bought it and it took forever to get things shined up. I like empting the press when I leave the field, because I don�t know when I will be baling next. I sell most of my hay off the rack. Most of the time I can trip the baler and loosen the press I can remove the last bale without too much trouble. Straw is a little harder. As far as starting out in a new field. I just retie the first bale. Usually I have to bale about 4 to 6 bales before I get the press set the way I like it, and it may change if I started on the outside windrow. I have baled enough that most of the time I only have to change the setting is a turn or two.
John In Iowa
tim[in]
05-24-2005 17:32:13
yeh i was going to suggest the straw thing. usually when i baled the hay would be real dry. usually just left the last bales in the baler. sometimes did the straw thing. i never knew anyone around here who emptied the chamber after baling.
DavidA
05-24-2005 09:51:54
You don't have a problem. The last bale will not come out without taking the bale apart. If the bale would come out then you would have a problem, something would be to loose.
If you take the last bale out, next time you bale hay the frist few bales will be loose until the bales start getting tight in the bale chamber again.
Illinois Boy
05-24-2005 10:04:59
 Re: Stuck Bale (Ford 532 baler) in reply to DavidA, 05-24-2005 09:51:54
Thanks DavidA...
That makes perfect sense... shows how little I know!!!
Roy in UK
05-24-2005 11:06:35
 Re: Stuck Bale (Ford 532 baler) in reply to Illinois Boy, 05-24-2005 10:04:59
The only reason the bales come out at all is because the material from the next bale been formed is pushing it out, so if nothing is going in..... .
Illinois Boy
05-24-2005 12:05:48
 Re: Stuck Bale (Ford 532 baler) in reply to Roy in UK, 05-24-2005 11:06:35
Thanks Roy...
I feel really stupid - you"d-a-thunk I"d have learned something by now, even though I"m new to hay farming. I"ve covered a lot of row crop ground but have never done much with hay - this is the first square baler I"ve ever owned.
Thanks guys!
Jim.UT
05-24-2005 14:23:04
 Re: Stuck Bale (Ford 532 baler) in reply to Illinois Boy, 05-24-2005 12:05:48
The problem I was having is that the last bale would sit in the chute between cuttings and go rotten. It seemed like a waste. But I don't have any animals to feed the stuff to so pulling it out flake by flake was just a mess for me.
Also, if I cleaned out the baler between uses I would have the previous mentioned problem of the first couple of bales would be too loose. So one day someone here gave me a tip:
Before starting out, feed a couple bales of straw into the baler to pack the chute. Trip the knotters before starting on your first windrow of hay so that the straw is separated from the hay. Those first two bales of straw will drop out the back first. When you're all done with that field, trip the knotters again and go back and feed the straw back into the baler to push the last bales of hay out. Then when you start again you have a packed chute and all your hay is in the field.
This can be particularly handy if you use the baler on various different kinds of hay or for various different customers. Every field keeps its own variety of hay and your baler stays packed and ready. Works for me.
Steve (Magnolia, TX)
05-24-2005 14:24:46
 Re: Stuck Bale (Ford 532 baler) in reply to Jim.UT, 05-24-2005 14:23:04
Hey...
That's a good idea, Jim...
I may 'borrow' it, myself...
Steve
