Hesston PT-10 Clogging UP
Joe in IN
05-22-2005 22:04:35
You helped me so much lst year with my sickle bar any tif bits for a semi-rookie with a borrowed mow-co??
Cut Alfalfa/Timothy yesterday. Everything was about 30 inches tall but had fallen over on me. Any secrets(besides a drum mower or disc mower) to cutting tall and thick alfalfa/timothy that has been blown over?
I spent more time off the tractor unclogging the far end than I did riding the tractor? Seemed to cut ok but then just didn't get through the rolls. Could moisture affect this? Ground was a little damp. Is there something that controls the roller tension?(This is a loaner so I don't have a good working knowledge of it) The near end didn't seem to clog but the far end clogged 3 or 4 times a lap.
Thanks in advance....
BANJO1
05-25-2005 18:02:45
 Re: Hesston PT-10 Clogging UP in reply to Joe in IN, 05-22-2005 22:04:35
IF NOTHING ELSE WORKS TRY CHANGING THE ANGLE OF THE TEETH IN THE CUTTERHEAD. YOU CAN DO THIS BY MOVING A HANDLE ON THE VERY END OF THE CUTTERHEAD ON THE LEFT SIDE (GEARBOX}. IT WILL HAVE A NUT TO HOLD IT IN PLACE. THIS MAKES ALOT OF DIFFERANCE IN MINE. IT WAS CLOGGING AND WRAPING UP AROUND ROLLERS. GOOD LUCK.
justplainjim
05-24-2005 08:47:59
does that knife have a half section at the end?
make sure that little critter is cutting or it will plug and drive you crazy.
Tim IN
05-23-2005 09:50:36
If your plugging at the rolls, I would check the windrow forming shields. Also, wet crop seems to accumulate on the float spring and skid shoe which then backs up into the rollers causing a plug. There isn't much distance between the rollers and the spring. I try to look back thru the header and see how much accumulation is on the top of the spring while mowing. If I am not seeing some of the spring for a while, I get off and clean, which sure beats pulling out plugged crop in the rollers.
Gerald J.
05-23-2005 08:07:35
Took me years to find that cure. Turned out the end guard didn't ride up against the mower section so it didn't cut well. Needs a washer or two as a shim to line up that guard.
I tried extra pipes to guide the hay and set the reel down low (which helped) but it was simply guard alignment on mine.
Gerald J.
