shims on spindles
spindle movemen
05-21-2005 16:05:47
I've got a hay wagon with some loose front spindles (side that is on the frame, wheel bearings are tight). I figured I'd just shim it since they are machined rounds in holes. Question is do the shims work best on the bottom where the weight squashes them, or on the top? Thanks!
Leroy
05-22-2005 06:05:01
 Re: shims on spindles in reply to spindle movement, 05-21-2005 16:05:47
There should be a thrust washer to carry the load, that is probably wore out so that with the weight you can still turn the front wheels side to side, without you could hardly turn them under load
spindle movement
05-22-2005 10:27:27
 Re: shims on spindles in reply to Leroy, 05-22-2005 06:05:01
turning was no problem, I had alot of sway in the wagon and slop in the frame half when the tire is off the ground
