#8 Little Genius Question
VanO
05-19-2005 18:25:41
I was wondering, if one of you with a completed plow had a picture of the chain that suports the trip lever pull rope in the middle of the landside lever arm. If you do will you post or e-mail me. I'm rebuilding a #8 and would like to know what the orginal looked like. Thanks for any help.
RustyFarmall
05-20-2005 04:59:19
 Re: #8 Little Genius Question in reply to VanO, 05-19-2005 18:25:41
I am not sure that mine is correct, but I will dig out my manual later and compare to what is on my plow. Basically what is on mine is the inner race of a bearing supported with a length of wire, and the rope just runs through it. I'll do some research.
RustyFarmall
05-20-2005 07:36:56
 Re: #8 Little Genius Question in reply to RustyFarmall, 05-20-2005 04:59:19
According to the manual the ring I have is correct, but it actually attaches to the small lever that you squeeze to release the catch for adjusting. I think the chain has a cotter pin, this cotter pin is used to secure the squeeze lever to the handle. Does this make sense?
VanO
05-20-2005 12:15:33
 Re: #8 Little Genius Question in reply to RustyFarmall, 05-20-2005 07:36:56
Yea Rusty I was thinking that the end of the rope might atach to the lever some how. I was told to atach it to a bolt on the seat, but if you did that and hung-up on somthing and pulled the plow loose, you would tare somthing up. Thanks for the help. Vano
RustyFarmall
05-21-2005 05:15:24
 Re: #8 Little Genius Question in reply to VanO, 05-20-2005 12:15:33
The rope does attach to the seat of the tractor, otherwise you couldn't reach it. You attach it with a piece of soft wire, secured tightly to the rope, and then make a sort of hook on the other end of the wire. Hook this onto the seat, don't twist it or anything, just hang it. If the plow trips loose from the tractor, the wire will simply remove itself from the seat, no damage done.
