Dirt Scoop.....smaller that 24 inch ??
Pooh Bear
05-19-2005 16:54:25
One of my neighbors today asked me what size
dirt scoop I have. 24 inch.
He has a small sub-CUT. The 3pt lift arms will
only spread to 20 inches apart.
Can he get a dirt scoop to fit this.
He wanted me to ask about this.
Thanks.
Pooh Bear
Pooh Bear
05-21-2005 11:37:38
 Re: Dirt Scoop.....smaller that 24 inch ?? in reply to Pooh Bear, 05-19-2005 16:54:25
I've searched for a small scoop.
and not found anything like that.
Mite work turning the pins around.
Could take the pins out altogether and run a
piece of rebar all the way across. Could put it
thru the eyes on the lift arms. This mite work.
Otherwise his only option is to have a scoop made.
Pooh Bear
Dwight (ks)
05-21-2005 06:08:40
You might try turning the scoop's lift pins from the outside of the bracket to the inside.
I had a dirt scoop and needed to do that. It worked fine after turning the pins around.
dwight
jhill
05-20-2005 04:58:56
Ford - New Holland used to sell a scoop for the compact tractors. Might look for one of those.
