sperry-new holland 259 hay rake
waynek
05-17-2005 18:07:15
when were the 259 rakes made?
i hava a 258@a 259. the 259 is a dolly,thats the only diff. i see, except it has grease fitting on bars where 258 is sealed.
Steve from New Holland
05-18-2005 04:29:58
 Re: sperry-new holland 259 hay rake in reply to waynek, 05-17-2005 18:07:15
Hi, when the 250 series rakes came out in the mid 60's, New Holland made the 258 with 100 teeth on it and made the 259 with 155 teeth on it. Later, they dropped the 259 and just made the 258 with the 3rd hole drilled in the bars to add the 3rd tooth. Everything else is the same. Steve
waynek
05-18-2005 03:39:14
no, it is a single rake left hand just like a 258.
9 ft.drag type.the 260 is right hand.i have both set up in tandem,258 on drawbar,hitch on back with extencion for the 259 dolly,both throw left.
2x4
05-17-2005 23:12:28
is that a righthand-lefthand rake set-up, that, when pulled together, makes a single windrow?
