MF 34 Swather .... electrical question !
Way Up Here
05-17-2005 06:56:50
I have an engnine here taken from an early 60's MF34 self propelled swather (at least that's what I was told it was from). Did Massey still run 6 volt systems then or would it have been 12 volts. It still has the original generator and starter with the unit and neither one designates the voltage. They are Delco units.
buickanddeere
05-17-2005 07:16:04
 Re: MF 34 Swather .... electrical question ! in reply to Way Up Here, 05-17-2005 06:56:50
What are the numbers on the Delco's? Even if they are both 6V. Odds are you could get away with a 12V battery, 12V regulator and a 12V coil or a 6V coil with a ballast-bypass start.
