New disc mower, but no tedder?
Luke S
05-16-2005 07:06:55
I bought a new Vicon 7'10" disc mower to replace my aging JD 1217 Moco. But I do not have a tedder and can't afford one right now. Assuming weather conditions are right(80+ temp and sunny) can I cut one day, let it lay the next, and rake and bale on the third afternoon? There is one fella around here that I have seen cut with a disc mower and roll it over twice the next day with a rake then bale it that evening and it look like it works ok. What do ya guys thing?
RickB
05-16-2005 15:57:19
 Re: New disc mower, but no tedder? in reply to Luke S, 05-16-2005 07:06:55
As stated, too many variables. "Here" I know of no serious or even casual haymakers that don't condition with either impellers or rolls. A tedder is also nearly a necessity. I certainly wouldn't want to make hay wthout either one!
thurlow
05-16-2005 07:59:26
Too many variables to give you a definitive answer; what kind of hay; how thick is it; what's your humidity like, etc. Cutting mixed grasses (Fescue, Orchard grass, bermuda, some White, Ladino clover, etc) in the Spring/early Summer, it always worked for me as you've suggested, i.e. cut Mon, rake and bale Wed; later in the year, when the temperature's higher and moisture content lower, I would often bale the day after it was cut..... .
Luke S
05-17-2005 09:48:57
 Re: New disc mower, but no tedder? in reply to thurlow, 05-16-2005 07:59:26
But what did you use to cut and did you use a tedder afterward?
thurlow
05-17-2005 11:32:14
 Re: New disc mower, but no tedder? in reply to Luke S, 05-17-2005 09:48:57
John Deere 270 disc mower, no tedder, Dura-bilt 10-wheel rake on the type hay mentioned. When cutting Sudex (Sorghum/Sudan grass hybrid), have used either Tarrup disc-mower/flail conditioner or NH 289 sickle-mower roll crimper/conditioner. The Sudex is usually about a 4 or 5 day deal.....cut Monday, bale Thursday or Friday. Usually needs to be raked/turned, although at times can be baled in the windrows just as it comes from the conditioner..... ....Only used a tedder one year; Deutz/Fahr which we couldn't keep together and is sitting out behind the shop rusting down. My hay is all for a commercial beef cow/calf operation; while the quality is important, it's certainly not as important as that fed to high dollar horses or dairy cows.
DaveH
05-17-2005 21:46:05
 Re: New disc mower, but no tedder? in reply to thurlow, 05-17-2005 11:32:14
Hey Thurlow, what model Deutz tedder do you have? I'm needing some parts.
thurlow
05-18-2005 09:49:47
 Re: New disc mower, but no tedder? in reply to DaveH, 05-17-2005 21:46:05
The thing has 15 or 18 years worth of honeysuckle and multi-flora roses growing up through it; if I can get to it, I'll look (may can find the operator's manual, which would be simpler); may be a day or two..... ...
DaveH
05-18-2005 20:21:45
 Re: New disc mower, but no tedder? in reply to thurlow, 05-18-2005 09:49:47
I've got a KH500 four spool and one of those silly combination tedder/rakes (which doesn't do either one very well) I'd be interested in your manual if it's for one of my machines (provided you want to part with it)
Luke S
05-17-2005 12:12:32
I am mainly doing mixed grasses and some timothy. No sudan or alfalfa or anything else, just some fescue, and timothy. I am going to give it a try with just my disc mower and only cut when I know I am going to have a 3-5 days of decent weather. I might be able to afford a new tedder in a month or so but after spending $3000 on my Oliver 1955 to get it ready to bale and buying the new disc mower and the new Kubota ZD21 zero turn mower I am a little poor right now. I got right at $40,000 in this hay hobby now and gonna do 100 acres this year. We'll feed about 25% of the hay to our own horses and donkeys and I'll be selling the rest so it is not a money maker but I enjoy it. The wife doesn't seem to mind me spending all this money on this deal, she keeps telling me if I need it, buy it. My grandpa tells me some people have $50,000 boats or moterhome's and the like, so if I enjoy doing this(which I do), whats the difference. But I am beating my brains out on weather I need a tedder or not. I guess I'll run without one for the first two fields which I'll be cutting this weekend and see what happens. It'll be about 15 acres or so, so it'll be a good test run. Thanks for the info fella's. I appreciate it.
