Disc Harrow center buster
txgrn
05-15-2005 05:32:35
How deep do you put the center buster for a disc harrow that is used to plow? Even with the bottom of the discs?
Do you want a chisel tip or sweep? If sweep, how big for a n 8' disc with 22" blades?
Thanks,
Mark
txgrn
05-16-2005 05:42:04
 Done deal in reply to txgrn, 05-15-2005 05:32:35
Well yesterday I got to bummin around the scrap pile and came up with enough parts to rig up a buster that I thought would survive the test of time. Got a 6" sweep and mounted it about a foot behind the front blades and about 2" shallower.
Tried it out late yesterday and it works. Whoopee! Finally happy with the plow.
Thanks for your inputs.
Mark
Leroy
05-15-2005 06:25:34
 Re: Disc Harrow center buster in reply to txgrn, 05-15-2005 05:32:35
I see those things in the books for disc but they were NEVER used here in Ohio, have never seen one and farming for 50 years
txgrn
05-15-2005 06:43:34
 Re: Disc Harrow center buster in reply to Leroy, 05-15-2005 06:25:34
Well, I didn't have this problem till I bought these new discs. Rather than the smooth curve that was OEM, I thought I'd be creative and purchase the raised center type (not as big a cup as the JD cupped ones however).
Well, what this did was to offset the center discs from each other because of the raised center. I was able to reduce the gap by increasing the grazing angle of the booms, but still couldn't get it all.
But they are there. As mentioned to Allan, I studied used plows at a dealer yesterday and half of them had this hootus, or what was left of where one was once mounted. Those without it had the booms offset so that the front edge of the center blades were not even. This allowed ont to cut in front of the other and reduce the gap..... kinda like on a riding lawnmower with 2 blades. They tilt the deck so that the front blace can lap over the path of the rear one.
Thanks,
Mark
Allan in NE
05-15-2005 05:53:04
Hi Buddy,
How wide is your no-man"s-land? Probably 6-7" or so?
If so, I"d sure run a 6" sweep but only at about 3 to 4" deep. Just enough to knock that ridge outta there; otherwise you"re goona break that shank.
Did you mean 18" foot wide? Seems odd that an 8" disc would have 22" blades on it. :>)
Allan
txgrn
05-15-2005 06:37:54
 Re: Disc Harrow center buster in reply to Allan in NE, 05-15-2005 05:53:04
Yes it is odd, ole buddy (quick answer too, thanks).
I had this old disc, and in our clay, I prefer to use the disc as a plow but you never could plow very deep as (you say) the discs were too short. Well I fixed that. Bought some new scalloped discs and added about 800" and boy does this baby plow..... loads up my 100 hp deere on the second pass where the spools are a draggin.
The gap is about 6" as you mentioned. I looked at some harrows at a local dealer and as you say, they were mounted might stout. Gonna go with a 6" sweep I found lying around. I also found a 12" buzzard but I thought that would really break apart. Grin.
Thanks,
Mark
Anthony
05-15-2005 08:47:15
 Re: Disc Harrow center buster in reply to txgrn, 05-15-2005 06:37:54
This might be a stupid question. but if you are making multiple passes why do you have to worry about the center. Can"t you knock it out on the 2nd pass by running offset from the first pass, or is it more of a leveling thing?
txgrn
05-16-2005 05:38:40
 Re: Disc Harrow center buster in reply to Anthony, 05-15-2005 08:47:15
True.
But in my current problem, I have a field that I planted a month ago that is full of weeds cause of the cool spring and my haste to get the crop in. So I want 2 passes at the weeds; especially the ones that have roots like carrots.
Thanks,
Mark
