Thanks to the folks who gave me ideas on building the new body on the wagon. That job's done.I went to use my new - to - me wagon yesterday. I had a load of light trash from a house we're renovating on it. Took it to the dump (5 miles). The sucker weaved very bad. Couldn't go above 15 mph without bad weave. I know the reach is bent - was that way when I got it. I've read other posts about straightening the reach out - or I could get a new length of pipe. In another post, the things that are like king pins, bushings, linkage etc. were considered the cause of the weaving. I'm not about to replace all that stuff, as I usually won't use the wagon off the farm. There has been some welding done to the front end steering mechanisms. It looks like someone bent something, tried to straighten it and added some rebar welded on to make it stronger. They may not have gotten everything back to the right length with the correct toe in (I read on another post that front wheels should toe in 1/8 to 1/4 inch). If this is the real problem, I can have little brother (a welder by trade) fix the basic allignment. Here's the big question. Will replacing or straightening the reach fix some, most or all of the weave? How much, if any of the weave is caused by a bent reach as compared to the front end slop/out of allignment? For my use, I don't care that the wagon tracks a little crooked. I do care about the weave if I can fairly simply fix some or most of it. Thanks!
