what to use???
Joe Bloggs
05-13-2005 19:50:37
I have a job to do and I dont know whats best to use for the job. why I am asking is because I will have to buy something to do the job with and I want to get it right. I dont have enough time or money to experiment. so here it is. on the property I have the previous owner dimped alot od glass, carpet ,car parts and all sorts of stuff like that on the roads to make them all weather roads. he did this over along time and the stuff is buried to about 8 inches deep. I need to some how get all this stuff out of the ground so I can sell this place. I cant sell with this stuff in the ground. so I have a IH 454 tractor. so I need something to pull behind it that will plow up the ground and bring all this junk out. I dont have any plows yet. what do you think would work best for me
James2
05-14-2005 20:47:52
 Re: what to use??? in reply to Joe Bloggs, 05-13-2005 19:50:37
I cleaned out several old fence rows that had some trees, brush. Fence was old so it had both wood and steel posts. Dozer removed the large tree stumps, but did nothing for the rest. Ran a chisel plow 10 inches deep over twice and got some of the roots up, but it's main effect was to breakup the root masses. The next step was to run the field cultivator over that area. This removed all the roots and a mess of broken off steel posts. Bottom line is that I think you are going to have to use a chisel plow/sub soiler to work deep and loosen it up, then use something with shovels to drag the stuff to the surface. I really have sympathy for you, it's going to be a tough job.
paul
05-14-2005 18:22:59
When you figure out how, let me know. Sis has about 1/2 acre of that on her new place. Field cultivator pulls up about 6" deep, chisel plow pulls up about a foot deep. But there are lots of little bits you don"t get.... Wonder what a rock picker would do for you, need to loosen the ground up first tho?
--->Paul
