NH 461 haybine
Willy P
05-09-2005 19:31:52
I have a NH 461 haybine and I was going to replace the wheel bearings on the left side,the side that you have to take the plate off,and then does the spindle have threads that screws into the hub to adjust the wheel bearings? This one does not ot the threads are all stripped out,does anybody know if it is supposed to have threads or how do you adjust the wheel bearings? Thanks
Steve from New Holland
05-10-2005 04:22:58
 Re: NH 461 haybine in reply to Willy P, 05-09-2005 19:31:52
Yes Willy, the spindle is threaded into a hub. This was not one of New Holland's better ideas. In fact, it is a dumb idea, but it generally worked ok. There is no slotted nut with a cotter pin. Steve
